KAM 125 and a broken gearbox....
Discussion in 'Bike Chat' started by BlokeOnABudget, Aug 1, 2023.
  1. BlokeOnABudget
    BlokeOnABudget Member
    Neco Abruzzi 50
    Well, after months of jumping out of first gear it finally died. First of all it jammed in gear at a roundabout traffic light, then it just made grinding noises. Managed to get home by starting in second, but I fear the 'box is done for. Question now is do I repair the unit in the bike, or look for a replacement engine?
  2. Stevep
    You've two options.
    1. Strip the knackered one and do the repair, refit and run it.
    2. Source a replacement, run that.
    Then strip the first one, powdercoat the cases/engine covers, full gasket set, piston and barrel and crank upgrade, new bearings.
    Make it look like a diamond.
  3. BlokeOnABudget
    Neco Abruzzi 50
    If I'm going to rebuild the engine I'll REBUILD the engine, you know what I mean? The crankcase needs to come apart to get to the gearbox anyway, so I may as well *ahem* rebuild it better. Meanwhile I have no functional motorcycle, although I do still have Drutt the stripped down scooter.
