just fitted c16 scooter misses at high revs
Discussion in 'The Workshop' started by grantmc3, Sep 1, 2010.
  1. grantmc3
    grantmc3 Member
    piaggio nrg mc3
    hey i have just fitted a yasuni c16 pipe to my scooter and when i try open the throttle at high revs it sounds like it hits a rev limiter could this be it backfiring or is it because i need to down jet my carb although it does no feel like it is running rich it js misses every couple of seconds at high revs when i hold open the throttle has this ever happened to anyone else thanks for any help
  2. Gilly-93
    Gilly-93 Member
    Aprilia Sr70
    what jet u got in, is it the standard carb,filter etc..........
  3. grantmc3
    grantmc3 Member
    piaggio nrg mc3
    i have standard carb 17.5 and a polini air filter with pm tuning reed valve. i used to have a leo vince tt on it and it ran fine but wanted a c16 for the performance. i also have lightened the rollers for the exhaust but don't no jet size i will check tomorrow in morning do you think it needs a smaller main jet
  4. capri dave
    capri dave Active Member
    keep a close eye on your plug colour!!
    c16 usually requires a larger main jet than a TT, stick a fresh plug in, ive had 1 or 2 plugs that have run fine, then miss/breakdown on full throttle...
