Hi Guys, I want to incorporate the Aerox rear disc brake (and rear wheel) into my Jog RR project. Do I need the complete LH engine/transmission casing from the Aerox, or just the brake parts? Shelton
Lot of hassle for no gain. You'd need to the crank case but iirc TNT do some kind of wheel adapter which might allow you to run the disc wheel on your drum braked engine. Murerg has used one on his bws so you could ask him about it; http://www.scootershack.co.uk/threads/mbk-booster-rocket-minarelli-vertical-ac-made-in-france.23802/ Might save you a lot of pissing about swapping cases.
If you really want a disc you will need a new engine case (or weld the support for the caliper to go on the case.. seen it done before but would have to be done professionally as there is no messing about with brakes). You would be easier using a wheel adapter to put a rear wheel (disc) on a rear drum engine case and only have a disc at the front. They are about £50. I can PM you a link to a website that sells them if needed. Bws and Jog drum brakes are the same so you can use the same as mine.
