Jog RR 70cc Tune
Discussion in 'Scooter Tuning' started by Filip, May 11, 2014.
  1. Filip
    Filip Member
    I've recently fitted a 70cc kit to my Jog RR and when it had a 50 kit on it, the power would be the same from 0-50, you wouldn't hear the revs drop or anything, now i've fitted a 70cc kit, i've put a 100 jet in an upgraded the airfilter, that runs perfect, but when I accelerate, 0-20mph is almost instant and then the revs drop, and quite quickly build up into top end, what do I need to change to keep the revs the same from 0- top end? I've got a stage6 sport pro variator with 4g rollers, Polini belt and Naraku Sport clutch.
  2. hairyjim
    Got a gilera ice
    Ile start the ball rolling and see what happens...what 70 kit?standard pipe?carb size,standard? You say a 100 jet runs fine...but it ain't if it ain't picking up.there's one or two good carb brains on here that could help eliminate that as a prob.cant see the rollers being a problem..bloody hell..low weight for off the line screaming..4g should do it..so many things could give them symptoms..slippy over grippy belt.might need s stronger torque spring to keep it low geared till it picks up.clutch adjustment?
  3. Filip
    Filip Member
    Motoforce Sport 70cc, Stage6 Sport Pro Rep exhaust, 12mm carb, the belt is fine, i've got two belts and they both run pretty Mich the same, but I find the standard belt to run better, I also have a Polini belt, and the torque spring has been upgraded to a stronger one already, can't remember the weight, its one that comes with the stage6 sport pro variator.
  4. hairyjim
    Got a gilera ice
    12 mm carb..sure that's a number reversal,Ile assume 21 mm.if not ,sort the carb size.have you tried it without the torque spring.have a look at the needle,try it up or down a few notches.that pipe is a bit top end power loving,not good till its got a bit of revs to play with.if your any where near a dyno have a session..bout £20 for a run up and advise.
  5. bogey
    bogey Active Member
    I'm having pretty much the same issues but as I bought the Drag with the 70 kit already on I'm not sure what rollers I have etc. Mine has the 12mm carb as well.
  6. hairyjim
    Got a gilera ice
    my Honda vision has a 12 too but it ain't pulling air for a bbk.gotta 19mm on my chink.21 if your looking for a carb to do it a bit of justice.yasuni r.soif hes got a 12,ide say..CHANGE IT.
  7. Filip
    Filip Member
    I think its the 12mm carb not keeping up with the power
  8. hairyjim
    Got a gilera ice
    filip..youle will find a21 copes a lot better.if you have a look on ped parts"exhaust pipe/barrel comparison/shoot out blog...loads of info.not just what to change..what they changed and worked.theres a set up like yours on there..
    BOGEY..Same advise..fat carb..21mm.if your using a good revving pot..24 if its a top flight set up.god knows on jet sizes.
  9. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    You could try riching up the middle by raising the needle and lightening the rollers a bit. But yeah- a 21 mm carb, or at least a 17.5 is a good idea - and for lots of reasons. Get the jets for it and be prepared to increase as much as 20 points. Jetting is really the crux of any set up. If you have lots, you can get it right.
  10. bogey
    bogey Active Member
    Do you ditch the standard air box then.
  11. waynesworld
    waynesworld Member
    21 mm carb open air filter will do it and re jet the 21mm carb
