Jetting
Discussion in 'Scooter Tuning' started by chad57, Aug 12, 2008.
  1. chad57
    chad57 New Member
    I need so advice on jetting
    iv got a runner 70
    Mhr rep 70 , pm baby 59 , malossi 21ml carb , malossi reed petals.
    and i duno what jet to put in it.
    Any ideas ?
  2. DYS VTR
    DYS VTR New Member
    skanky cRaKwhoR3s
    open filter or standard box?
  3. Sw1fT
    Sw1fT Active Member
    200SX S13
    an introduction would be nice aswell
  4. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    x2
    i hate people that just jump straight in and ask questions without an intro :rtfm: :wallbash:
  5. MiNoR cOnFuSiOn
    i had a pm... same as EVERY new member seems to directly ask me silly things like this..
    1. theres a guide on jetting/rollers
    2. theres a million and one bikes about with a similar setup but just to keep things simple
    start at around 92 with the jet, it will be big. never used a pm 50 pipe so wouldent know on rollers.. would guess around 4.5 and work heavier till the revs drop off (read guide if you dont understand) should get you runbning atleast ;)
  6. chad57
    chad57 New Member
    jets
    sorry
    Im running a k&n air filter
    i had a 95 in there and it run to rich and spluttered and boged then i put a 88 in and about a week later i had a hole in my piston and iv tryed inbetween i put a 92 in and it still run rich
  7. MiNoR cOnFuSiOn
    its too much mix not too much fuel in the mix.. drop your roller weight. sounds like there holding it back. like i said bang the 92 in.. it will be rich but wont cause any harm and you should be able to set the transmission up with that jet.. once the revs are doing what theyt should lean the jetting out ;)
  8. chad57
    chad57 New Member
    ok thanks il try it :D
