Jetting tutorial video
Discussion in 'The Workshop' started by CA Zip tuning, Apr 3, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    Could someone please make me a jetting tutorial before I upjet my ped thanks
  2. oliwest
    oliwest Member
    aerox road legal pit
    Mate its not hard! Do you know how to get to the jet? Start from the biggest jet an work your way down an check the colour of your plug
  3. CA Zip tuning
    lol i know but im new to this stuff and do not want anything to go wrong
  4. oliwest
    oliwest Member
    Id getstep by step pics but both my laptops are are broke :/its easy! Undo the metal clip that hold carb onto the rubber manifold pull the carb out. Get a flat head screw driver, there are 2 screws on the bottom on the carb, undo them. Some fuel will spill out but its ment to. Then look at the carb there will be a small jet an a bigger jet. Unscrew the big one then fit your new jet. Screw float. Bowl back on an refit the carb :) itll take 10 mins at most an youll laugh at how easy it is
  5. CA Zip tuning
    what about the petrol pipe lol when i took it off the carb little bits of petrol came out
  6. ramo
    ramo GoldMember
    That's just the petrol that's in the pipe perfectly normal as long as it it stops after a sec
  7. oliwest
    oliwest Member
    I dont take the petrol pipe off :L i just leave the pipes and throttle in an can still remove the float easily :)
