Jetting/ spark plug colours
Discussion in 'Scooter Tuning' started by Aerox Aaron, Mar 18, 2008.
  1. Aerox Aaron
    Aerox Aaron New Member
    On that picture the colours described are when i put an 80 main jet in, from 72 because of open filter
    The two top parts are now a tanned brown at 78
  2. White aerox
    White aerox New Member
    Thank you for asking that question because i think my bike is spluttering at low revs cos my main jet is to high because if you have that setup and with an airfilter you jet is 80 lol mine is 82 without an airfilter but setups are pretty much the same
  3. runner 180
    runner 180 New Member
    if the spark plug is to dark your running to lean
  4. kyle1b1
    :msn1:
    is the spark plug is dark(black) is running rich.
    if it is like a rerally white colour is lean.
    it wants to be a chocloatly brown.
  5. Aerox Aaron
    ty for that, but i meant which part of the plug ?
  6. kyle1b1
    it will be pretty much all of it. and dont let it idle then check :rofl:
    to do main jet need to go on a decent full throtle run.
    find a decent long road or an hill or something go down it full throttle then pull over whip it out and check.
    carefull will be warm :rofl:
  7. MiNoR cOnFuSiOn
    if its spluttering at low revs its fuck all to do with the jet.. jet is only full throttle setting. if its at low revs at full throttle your transmission isnt setup right
  8. White aerox
    transmission such as what?
  9. alperin
    alperin Active Member
    aerox 180cc
    :_)
    such as rollers, clutch springs, contra spring i have the same problem but my one happens for bout a 5 min ride and den its all back to normal
