jet size
Discussion in 'Maxiscooter Tuning' started by mrhappy, Sep 17, 2010.
  1. mrhappy
    mrhappy Member
    Hello i need some help with my typhoon 125 . when i got it it had no air box fitted and a power pipe after running full throttle for .5 of a mile or so :cray: hole in the piston i have since replaced the barrel and piston allso fitted the correct air box . can any one tell me the standard typhoon 125 jet size so i have a base mark to work from or advise me as to the jet size to fit so no more melt downs thank you
  2. GUNS
    GUNS the usual suspect
    racing SP70 & LX172
    if it has MIKUNI VM Slide carb; and only,
    MAIN JET 82.5
    PILOT JET 35
    STARTER JET 40
    NEEDLE POSITION 3RD notch from top.
    PILOT SCREW SETTING 1&3/8 turns out.
    Check the make of carb first.
  3. MiNoR cOnFuSiOn
    it probably died at part throtte... same as most typh's do when you put a filter on. it needs the needl lifting and idle mix ajusting. it will still need a bigger jet for a filter.
  4. mrhappy
    mrhappy Member
    nice 1 got it going well now \o/
