Jet size??
Discussion in 'General Scooter Discussion' started by haz_666, Apr 29, 2007.
  1. haz_666
    haz_666 Member
    Hi,
    How do i find out the jet size of my runner without taking it all apart, and what size should i want it to be about?
    Nice one guys
  2. Sw1fT
    Sw1fT Active Member
    200SX S13
    why do u want to upjet? what mods have you done etc
  3. wobbly_trials
    if it runs right then leave it alone.
  4. haz_666
    haz_666 Member
    well im not sure if it does run rite....
    when i first turn the bike on if i rev it then it will cut out... i can only assume this is due to the engine being cold as if i leave it for a while it will be fine.
    Cheers
  5. wobbly_trials
    it is indeed because it's cold.
  6. haz_666
    haz_666 Member
    is ther anything i can do to speed this up as it takes quite a while??
    Cheers
  7. wobbly_trials
    not unless you want to bugger the motor. it should be at least 5 mins before the bike is fully ridable. try cleaning the carb and making sure the choke is working properly.
