hello, i have a 70cc aerox the kit is athena 70cc aluminum 1 ring and carb is 19mm DELORTTO the jet now is 72 and i with standard airbox the aerox start with the airbox and if i want to drive i need to put out the airbox if i will stay with the standard airbox and i will put al full gas the aerox will turn off the aerox stay on rpm with the close airbox but withot the airbox he not so i need anther jet? i think smaller i right? thanks
id think bigger mate, with my zx pipe and standard 50 im running 68, gonna stick a size 70 in cause its not big enough i dont think
try popping the breather out of the top to give it more air, failing that. run a filter or just jet to run with airbox
u deff need a bigger jet i have a size 72 in ma aerox nd that has standard exhaust just de restricted
