Jet Help!
Discussion in 'General Tuning' started by B33DL35, Feb 2, 2012.
  1. B33DL35
    B33DL35 Member
    Piaggio Diesis 100
    hi all, i have recently brought a zx leo vince exhaust for my bike and i was told i would have to get it to get max performance out of it. it has standard variator and stand clutch springs, i will buy a variator set ect if needed?
    thanks
  2. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    if its the same engine as my aerox 100cc then i have the following
    zx pipe (includes 7.7gram rollers which are too heavy i found)
    im currently on 6,3gr of rollers
    Jet size stock is 76 in my tk carb, i whent to an 86 as its the next biggest i could get in stock
    the pipe looses most of the low down torque i found and i have had to fit the stiffest malossi clutch springs
  3. B33DL35
    B33DL35 Member
    Piaggio Diesis 100
    cheers for your help m8, i think my rollers or the clutch spring is on its way out because as i pull off it jerks and once it gets too bout 10mph its fine. i tried to remove the variator nut to check the rollers but struggling to get it off as everything turns.
  4. creamsodauk
    Runner 125 SP
    you need to use either a variator holding tool or an impact gun, or a piston stopper
  5. B33DL35
    B33DL35 Member
    Piaggio Diesis 100
    i was told to use a piston stopper but would that damage the top of the piston?
  6. creamsodauk
    Runner 125 SP
    not if you turn the engine over by hand until it touches the stopper, then apply gradual force on the nut your removing, ie dont slapp the stopper in, then jam the rachet hard and have the piston spin round and smack the stopper.
    pretty easy to use and fairly safe, i have used mine a fair few times
  7. B33DL35
    B33DL35 Member
    Piaggio Diesis 100
    sound ill have to order 1 and try it out
