Jet Confirmation!
Discussion in 'General Tuning' started by Cardie, May 21, 2012.
  1. Cardie
    Cardie Member
    Order some jets for my ped (50 to 72)
    What jet should I need with this set up
    SR50
    70cc Stage6 Streetrace
    Stage6 Pro Replica
    4.5g Stage6 Rollers
    Malossi Clutch Springs (Yellow)
    Standard Airbox with restrictor in
    I am going to take out the restrictor in the front of the airbox,
    Ive put these yellow clutch springs in as mine were too soft to set off properly now ive got this horrible surging at WOT till about 40 and massive delay in thorttle response.
    Chucking out wayyyyy too much blue smoke when its cold (buy to much I mean it will last 10 15 mins of riding before it will acclerate witout misfiring and spluttering!!
    So what jet should I need, the lad at ped parts said a 68 to 72 should be good?
  2. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    Which engine is fitted to your bike?
  3. Mr Bizzle
    04 Aerox 70 stage 6
    Oh, and what size carb?
  4. Cardie
    Cardie Member
    Piaggio C364 17.5mm dellorto
  5. Mr Bizzle
    04 Aerox 70 stage 6
    It sounds to me that you need to increase the airflow before you alter the jetting. My aerox when fitted with the stage 6 streetrace was a pig to get running until I removed the snorkel to the airbox.
    So I would get the airflow sorted first.
  6. Cardie
    Cardie Member
    Thats what im going to do, remove the airbox restrictor, so will a 70ish jet be okay?
  7. Mr Bizzle
    04 Aerox 70 stage 6
    My aerox with a 17.5 carb is running an 80 jet which I think is slightly too large. I know piaggio's run 10-15% smaller jets, so I guess your in the right ballpark.
  8. Cardie
    Cardie Member
    Cheers mate will let you know how i get on when i get the jets :)
