Jet and rollers?....again
Discussion in 'General Scooter Discussion' started by Dr MamBo, Jun 3, 2008.
  1. Dr MamBo
    Dr MamBo Member
    Right I finally got the variator out so I need to order my rollers. How do I determine what weight rollers I have so I can figure out which weight I need to order to go with the new exhaust and jet size? What sort of weight should I be looking for?
    I removed the old jet and it was size 70, so which jet sizes would you recommend I order?
    The pipe I got is the chrome stage6 race replica and its going on a minarelli horizontal a/c 50cc
  2. one7twoboi
    one7twoboi New Member
    u tried the search geez? :cool:
  3. Dr MamBo
    Dr MamBo Member
    I have indeed but everyone is different lol
    I understand that its quite a triel and error process anyway but I just need somewhere to start.
  4. capri dave
    capri dave Active Member
    order something like a 72,74 and 76 jet....
    and either look on your rollers for the weight written on them or weigh them on some kitchen scales....
    probably order a few sets of weights starting at half a gram lighter ;)
  5. Dr MamBo
    Dr MamBo Member
    thanks dave
    trust me to have rollers that dont have the weight written on. I dont have scales either so I think i'm going to have to nip into woolies and use the ones in the pick and mix section :p
  6. kyle1b1
    :w00t:
    be sure to get a few try before you buy sweeties :rofl:
    i just walk around eating them all :rofl:
  7. Dr MamBo
    Dr MamBo Member
    well of course! you just got to do that. Its almost law :rofl:
  8. Dr MamBo
    Dr MamBo Member
  9. capri dave
    depends what carb you got, some are 5mm (mostly aftermarket carbs)
    and some are 6mm (mostly std fit carbs)
    Note i did use the term "mostly" before someone says "my carbs aftermarket and uses 6mm jets!!
    have a look on your carb, the make, size and model number should be stamped on it somewhere...
    for example my carb has Dellorto 20.5 PHVB.
  10. Dr MamBo
    Dr MamBo Member
    I took a chance and ordered 5mm and suprise suprise they don't fit.
    :rofl:
  11. capri dave
    yeah thatll be a std fit carb then ;)
    you should of posted up your carb model and size, and i could of told you which to order ;)
