ah righty still quite young for a E46 (well over in good 'ol england lol been watching your project silently aswell its going good and lots of effort put inn nice ones
I have finaly found some time to worke a little on the Formula engine again. Viola, two new support bearings in place I have also bougth my self a new sandblaser cabinet. have not tried it yet, but it sure looks good :grin:
Great project John, I have neither the resources or patience, to do what you have done. I got an LC engine and ancillaries last week......... winter project.
I have just return from Crete. (Chania) Did see 2 Italjets at Crete. I only tok pictures of one. They don't even bother to take the key out of the igniton!! A nice street in the old town.
Finally I have got the crank installed The air filter tube dont fit Polini variator Nakaru twist control
Did test start the Formula today Did run it for only a few secound, but know I know there is LIFE :cheers:
Hi looks you know quite a bit about the italjet formula by now looking at your threads. I was wondering if you mayabe able to help me???? I have at the formula 125 project which I have posted in the projects section on here and the italjet forum to which you replied amny thanks. I have heard that the gear up kits for the formula 50 lc/suzuki ap will fit the 125 formula do you know if this is true or not? I have seen this one what do you reckon http://www.donotlink-pedstop.co.uk/...it_3_parts_for_Suzuki_AP_50_etc__12-3937.aspx Also I need some stronger clutch springs for it and do you know if the formula 50 springs would do as I have also heard the 50 and 125 share the same variator? Would be gr8 if you have any info........?
I don't know about the gear, but the clutch springe should't be a problem. I don't think the variator is the same, but I'm not sure about that either. PS: The link don't work because the administrators are a littel "childis", and have banned some companys. You have to add a space between some of the letters in the url, then I can copy it an remove the space.
Just some new pictures Did clean the gas and oil tank as well The old AC is finally striped and clean up a little as well Some pictures of the two Formulas together. One LC and one AC. Note the different on the frames.
The pacage from http://www.Italjet.co.uk has just arrived. Had to test the new CDI and guess what, it worked No more rew limiter. Now I can setup the carb when the spring comes.
Yes. Malossi have one https://www.scooter-center.com/scow...TALJET_FORMULA50LC&category2=CAT:CAT_ZYLINDER
