Italjet Drasgster rear wheel play
Discussion in 'Maxiscooter Tuning' started by matthew greeman, Apr 1, 2021.
  1. matthew greeman
    matthew greeman New Member
    Hello seem to have a problem with my Italjet Dragster.
    I seem to be getting a lot of play in the rear wheel. Originally is was the axle bolt coming loose but I have now put on the tsab locking ring which has stopped the bolt working loose.
    However now the bolt is staying tight but after a short ride the play still comes back the previous owner did run an extra washer in the hub which I took out but I believe it should only have one in there ?
    Once I have tightened it all up the play does disappear but then comes back could it possibly be a worn hub but I thought if it was this the play would be permanent even when tight ?
    Any one got any ideas ??
  2. Stevep
    Have you changed the gearbox bearing on the output shaft?
