It would be nice to have a rev-counter....
Discussion in 'General Tuning' started by gooseman, Apr 11, 2014.
  1. gooseman
    gooseman Member
    My scooter (italjet formula 50/70 lc) seems to rev up quite a bit before taking off & going up to its max of 55..sometimes 60 mph...I think its revving more a top speed but its hard to tell how much more.
    It seems to have a "sweet spot" around 50-55 where it is happy almost like flipping a switch..
    Im not familiar with tuning the converter/clutches/rollers/etc. but I feel like it should grab hold earlier in the rev range...what do you guys think??? jim
  2. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    Maybe your clutch springs are a bit too stiff. I would leave it alone. Usually the problem is that it won't rev high enough on take off. Changing the rollers for heavier ones might not help the top speed at all as the variator is maxed out at 55 mph. I think you've just reached the limit of the machine's transmission. Only changing the final gearing will help this.....
    The sweet spot is down to the cylinder/exhaust match. Frankly if you're hitting a sweet spot at 55/60 and it's taking off properly then you're doing good !
    Who set it up ?
  3. gooseman
    gooseman Member
    I just got this scooter in January & it is my first & only "new style" machine though its a '99 model, it came to me cross country from a dealer (2000 mileso_O) riding in a tractor-trailer. I took it for a short ride right away :D
    I decided to pull the bodywork & see what was underneath & put a new plug in it, I found the lines from the oil tank to the pump were plugged so a good thing, I had thought the injection was OK. I removed the air filter (stock box) and found the intake pipe had been sawed off so that air went past the filter instead of thru it...I inst a section of thin alum tube so air went thru the filter.
    I found that it had a Malossi cylinder..must be 70cc...also manifold & a 21 mm dellorto...it has the stock exhaust..not sure if that is restricted..bought a Leovince ZX pipe but haven't inst it yet...I know I will need to de-restrict it first.
    Yesterday I inst a Doppler air filter, the one with the clear top that looks like a pop bottle, it only had one small opening and the bike ran punky, I have now drilled out one of its other openings and will try again...don't want to screw anything up.
    I don't really know what all mods have been done to this scooter as its now 14 years old, was last registered in 2007....jim
  4. hairyjim
    Got a gilera ice
    Get a good pipe on it before you do anything else.malossi cylinder..take a pic and stick it up for identification.good pipe will make a malossi work nice.ped parts blog should help.P.P BLOG ADDICTED i am.may need to faff about with jets and rollers ,so do all the big stuff and the other stuff is last job..
  5. gooseman
    gooseman Member
    Thanks jim...guess I could be a "hairyjim" also as I have a beard & my hair is getting longish:eek:
  6. hairyjim
    Got a gilera ice
    there's alot of us about..since all the ginger stuff has calmed,we can feel safe.we don't need to hide behind visors..WE ARE HAIRY..dont be afraid of us..we need love too.
  7. gooseman
    gooseman Member
    I see quite a few old hairy guys like me around but UNFORTUNATELY they are riding Harleys :(....I love the two strokes... have six of them at the moment
  8. hairyjim
    Got a gilera ice
    im always moving about.got a chink that's gonna need a few quid spent and spanner work.88vision with unknown year afo5e lump to finish.if i got another one it would have to be swaps..two for one.
