Is this enough spray paint? Piaggio Typhoon
Discussion in 'Visual Modifications' started by rhysio, Mar 1, 2011.
  1. rhysio
    rhysio Member
    Typhoon 50
    I'm going to paint the back left, right and middle panels on my piaggio typhoon, after reading the guide on here I went and bought:
    1) clear lacquer >400ml
    1) matt black spray >400ml
    1) Grey Primer >400ml
    1) 1 sheet of every sandpaper reccomended
    Do you think this is enough or will i need more?
    Cheers
  2. morgz
    morgz Member
    if i was you i would deffo get more black to give it more coats and a better finnsih
  3. scott15
    scott15 Member
    Want an NRG MC3
    Usually when im respraying, ill get through 2 cans of each. And more than one sheet of sandpaper, but then i usually filler all the panels aswell. If your only keying the panels then it should be enough.
  4. lshigham
    lshigham Member
    Re: Is this enough? Piaggio Typhoon
    You'll probably need two of the black and primer.
  5. bandyleg
    bandyleg New Member
    Anything That Moves
    Hi bud im just in the middle of respraying my runner and i can tell you now that to do a proper job you have no where near enough stuff!! 1 sheet of paper is dreaming, as for your paint the black cover quite well usually only 2 coats but a minimum of 3 i would defo get yourself at least 2 more cans of primer and anothe can of paint should and one more lacquer!! The pic below is the paints i currently have large cans are primer or lacquer smaller cans are colour and i have thrown 2 colour cans in the bin and also a primer can and i will still need more of my chosen colour as it doesnt cover very well, car plan stuff isnt the best but it does work if you are patient and take your time!! Dont rush it!!
    Didnt meen to put a downer on it but in the long run it will save you a fortune! You can check out some of my paintwork in the project section under this is what £40 buys you and you can see that im not shitting you!!
  6. rhysio
    rhysio Member
    Typhoon 50
    Ahh thanks ever soo much mate, i'm gonna go and buy some more today.
    Cheers
  7. bandyleg
    bandyleg New Member
    Anything That Moves
    No worries bud good luck!!
  8. Acid
    Acid Member
    NRG 50, MBK Stunt 50
    80% of a good paint job is prep work
