is this a reliable set up?
Discussion in 'The Workshop' started by Isaac Knight, Jun 28, 2014.
  1. Isaac Knight
    Isaac Knight New Member
    I am thinking of buying a aerox standard and tuning it, I want to to put a mallosi 70cc bore kit, Doppler crank (anyone know how much it will cost to fit a crank at a garage), 6g rollers, mallosi multi varitator, mallosi belt, torque spring(not sure what one to get), race clutch springs, 19mm carb and manifold, is there anything else I would need to make it as reliable as possible, thanks
  2. MARSH
    Keep the speed down and don't thrash it to with in an inch of it's life every day and it will be fine!.
  3. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    I found this on another bike forum and it's so true.
    150+ due to the time involved in a strip and rebuild. If you are spending that money, then spend a bit more, replace the main bearings with new ones and get them to jet up the carb properly for you. A new crank on old bearings is false economy and could damage the crank if they are worn. get a Kevlar belt as they are more durable and will handle the stress of the upgrade better. You haven't mentioned a new exhaust, do you plan to keep the original one?
    Once this is finished, use the best two stroke oil that you can afford. Ideally, use a racing one as it will provide better lubrication to the aluminium cylinder and the piston. If you haven't cheap-skated on the cost of the parts, then why go cheap on the 2T oil?
  4. Isaac Knight
    forgot exhaust, it has bearings with the kit, yasuni type and carb will be set up properly and castrol racing full synthetic 2 stroke
