is this a decent bore kit
Discussion in 'Scooter Tuning' started by aeroxthrasher, Mar 4, 2008.
  1. aeroxthrasher
    aeroxthrasher New Member
    i fond this kit it says its ewuivelant to the mhr kit but i have no idealol so can someone help me out?
    also whatis a cheap but strong crank?
    cheers
    lee
  2. NJH
    NJH New Member
    you forget the link :confused:
  3. aeroxthrasher
  4. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    pm tuning so it must be decent.
  5. MiNoR cOnFuSiOn
    please, stop with the "pm so it must be decent" they made TWO decent ish pipes that are good fi you have a welder, the rest of there stuff is reboxed gear from smaller manufactors.. there cranks are ether top racing or bgm and tbh its all hype
    stick with sommin tryd an tested for 30+ years like polini/malossi
  6. capri dave
    capri dave Active Member
    And how can they claim that kit is equivalent to a rep...
    its only got 1 ring...and, you can buy reps cheaper than £160!!!
    I just did...from germany of course ;)
  7. dos
    dos Member
    Typhoon172
    its onlt 94 quid for a polini sport wtf u looking at that for :confused:
  8. am4n_am4n
    am4n_am4n New Member
    basically if you buy that your paying for the name...
    and ontop of that you got to worry abput the piston rings becuase it only has one ring as its a race bore
    once you fit that bore on your bike will be usless for everyday use i supose
    just stick to the cast iron bores like polini/malossi
    scooter attck do some good deals ;)
    hope this helped
  9. WOLFFY
    WOLFFY New Member
    I got a cast iron Malossi and it runs fine.
    No problems with it and I can hammer the shit out of it and don't need to let it warm up for 10 mins either.
    Go for Polini/Malossi
  10. Major Rel14b1lty
    Major Rel14b1lty New Member
    you do need to let it warm up, lol yours aint guna last long pal.
    1. the piston will heat up quciker the the cyl expand and score
    2. Oil needs to circulate to put a film around the cyl
    All engines should be warmed up
  11. MiNoR cOnFuSiOn
    all iuron barrels should be warmed up, if your r\unniong a correct ring end gap in a lined barrel you can rag from cold
  12. LIVELY16
    LIVELY16 New Member
    its a single ring kit , think of it like a disposeble camera.
    2 ring kit think of it like a man on viagra , can just keep going and going and going. till uve reached certain millage and it explodes.
