Is there a washer that goes behind or somewhere on the clutc
Discussion in 'The Workshop' started by GARLAND, Feb 29, 2008.
  1. GARLAND
    GARLAND New Member
    On a clutch Typhoon 125 engine.
    Is there ment to be a washer and you have one? :cool:
  2. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    yes there is, on the older shape engine there is a thick washer that goes on the shaft before the clutch on the newer style engine there is a slightly larger thick was that goes on after the whole clutch and bell has gone on, it sitrs on the shaft between the clutch bell and kickstart case hope this helps
  3. GARLAND
    GARLAND New Member
    ok where can i get hes. local dealer?
  4. Sw1fT
    Sw1fT Active Member
    200SX S13
    i have looked for a new one and i cant find it, might be easier to just make one up?
    it stops the rear pulley grinding on the gear case, look in my project and you will see that its happened.
  5. tErr0
    :wtf: Got one for my typhoon at a main dealer. They had it on the shelf and as far as i remember it cost pretty much nothing.
  6. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    been to a piaggio stockest i needed 1 for ce but they dont stock them i dont think usually i got one from the boys in the workshop so ask around
  7. tErr0
    Metropolis in vauxhall can get them and may even have one on the shelf.
    Part number 1 on that diagram so they do have a part number.
  8. GARLAND
    GARLAND New Member
    I'll go there tommorow where abouts is it.
    Vauxhall is on the same line as me if I come out of the station is it far?
  9. haugh
    haugh New Member
    You cant miss it from the train station its right across the road
    loaaaaaads of motorbikes out side
  10. GARLAND
    GARLAND New Member
    I rang them they said 2-3 days they ordering it but I don't think he will cos he said I have to come in and order it they dont do phone orders..
    Where else?
  11. tErr0
    You must have sounded dodgy on the phone then. I've ordered plenty of times over the phone and it's next day on pretty much all piaggio parts.
    I was in there today as well.
  12. GARLAND
    GARLAND New Member
    Haha. Urm if I ring them tommorow and they say they haven't got it do you think you can order it and ill pick it up.
    They msut not like me?
    What did you purchase in there :cool:
