Hi guys My Vespa LX50 idles slightly high intermittently. When in its stand the rear wheel spins also. I am having trouble locating the screw which helps change the idling however in the manual there are 3 type of idling screws and I am still having trouble finding it! I have 3 questions 1 - Where is the correct screw? 2- What issues can high idling cause? Clutch wear? Belt wear? Fuel wastage? 3- What could be causing it to idle high intermittently? Thanks in stressed and fed up anticipation
