INDICATORS
Discussion in 'The Workshop' started by lupo91, Jun 5, 2010.
  1. lupo91
    lupo91 New Member
    Hi all i have just bought a Clear Indicator kit for my nrg mc3 and also green bulbs
    I was just wondering if there was anyway of wiring a switch so i can put all 4 indicators on at same time like a car hazard lights?
  2. Blue dwarf
    Blue dwarf New Member
    No but you will get pulled and a rectification notice and or fine if you use any other colour than amber for indicators.
  3. lupo91
    lupo91 New Member
    i know they are for off road use just with my bike being black and green just wanted them 2 flash when I’m parked up at shows ect..
  4. wobbly_trials
    yeah, there is a way to do it, however you will have to change your indicator relay as your will be rated for 2x10w bulbs (more than likely) and suddenly you are doubling the wattage. you can get 10-20 watt relays from any good bike shop.
    the easiest way to get all 4 to flat at the same time is to fit a wire between the live on a left indicator and the live on the right indicator this should make all 4 flash when either left or right is turned on. its worth putting a switch on this wire so you can use them individually too!
  5. lupo91
    lupo91 New Member
    ok thanks will have a look when it stops raining :p
  6. scoot_woot
    scoot_woot New Member
    Yamaha jog R 50
    hello,
    I was wondering if you could tell me where I could find the indicator relay on my Yamaha jog r 50 because when i turn them on they don't flash they just stay on solid light.
