I had my rear number plate/light unit out the other day. The only wire I disconnected was the one leading into the light unit (the connector.) The left indicators are permanently on, when I switch it to right indicate, they stay on as well. The indicators don't pulsate. Any help would be appreciated Dom EDIT: Brand new indicator relay. Connections are all good. New battery.
well if they worked fine and then u disconnected a wire and now they stick why dont u put that wire back how it was?
that means you either need a new indicator relay or a indicator bulb has blew and all the power goes on one bulb causin it not to flash.
