Would it be necesary to adjust the cable on the oil pump to deliver a little more 2T oil, After fitting a 70cc kit to a Runner 50 engine?? or is it best to leave it at factory setting!! I was thinking, ive increased the bore size and increased the main jet but I never hear mention of the oil delivery being increased
you should wind the ajuster out to full extention (so the cable lys perfectly horizontal on the crescent at full throttle)
Thanks Minor, I was hopeing you would answer my question Ive adjusted the pump to your instruction...And its noticeably smoother and quicker
MiNoR cOnFuSiOn wrote: you should wind the ajuster out to full extention (so the cable lys perfectly horizontal on the crescent at full throttle) is that on the carb rite?? Kl[/quote]
think i need to do this to mine.. but ive never touched an oil pump before.. i know where it is.. but what would i do from there ? cheers ben.
Advance the oil pump a touch...it dont need much a milimetre or less!! you can always put it back to stock setting if your engine dont like it But think about it, people fit bigger cylinders and main jets but dont increase the oil ratio to suit....mines running much smoother now
