Increase braking on Zip RST...
Discussion in 'General Tuning' started by JerseyJim, Jul 3, 2011.
  1. JerseyJim
    JerseyJim Member
    '99 Zip RST
    Hey SS crew,
    i need more front end braking, end of... I have put new pads in, changed the fluid etc and the braking is ok but i feel that its not all it should be and i have little confidence in it. :beg:
    I want to know if there is a simple way to get better braking from the front end, be it a decent wavy disc and pad combo, or is there a bigger brake conversion available. Or can i fit forks and front wheel from a Zip 100 or similar to get some decent stopping power?
    All help gratefully received...
    Ta :thumbsup:
  2. tErr0
    Did you just put standard pads in?
    Does it have the stock brake hose on it?
  3. JerseyJim
    JerseyJim Member
    '99 Zip RST
    no i put in EBC 'sport' pads, but yes it does have the standard hose. The brakes just feel like i need to write them a letter to tell them that im going to use them... The front lever feels ok, and the back, well it feels like it is, a cable.
    I ride quite enthusiastically and am tipping the scales at 16st so effective braking is quite important...
    Thanks for the reply...
  4. tErr0
    I would try changing the hose for a braided one for starters. Standard hoses expand under pressure so give a sort of soggy feel.
  5. brettfield999
    brettfield999 Member
    Typhoon 172
    I replaced my hoses 2 weeks ago with goodrige lines. I bled them then applied the front brake just wheeling the bike around and I nearly dropped the bike with surprise. They are so urgent now. Just straight on
  6. MiNoR cOnFuSiOn
    use a wavey runner rear disk an caliper... it just about fits and absoloutly transforms the front brake... check out abs zip project for pics :)
