In need of some help
Discussion in 'The Workshop' started by Alex Barnes, Nov 12, 2013.
  1. Alex Barnes
    Alex Barnes Active Member
    Hi guys well I started up my bike and left it to warm as I always do and when I came back to get on it the garage was filled with smoke so turned off the bike and the smoke went turned it back on and saw it was coming from under the engine and there was a burning rubber smell I personally think its something to do with the clutch but im not sure if any 1 knows whats wrong then let me know asap thanks
  2. Mark farmer
    Mark farmer Member
    Could be head gasket gone and your smelling burning oil? Not good
  3. Mark farmer
    Mark farmer Member
    Is it four stroke or two stroke?
  4. Alex Barnes
    Its a rubber smell and its a 4 stroke honda cbr 125
  5. lee mason
    lee mason Active Member
    suzuki rg125 gamma
    not got an oil leak or any spilt on it cause it could be oil burning off it
  6. lee mason
    suzuki rg125 gamma
    also take the belly pan off so u can see exactly where its comming from
  7. Mark farmer
    Mark farmer Member
    Hmmm see if you can see exactly where the smoke is coming from, Or what lee said look to see if there's any oil leaking on to the head
  8. Mark farmer
    Mark farmer Member
    Remove the dip stick and have a look why colour the oil Is as well, if its a creamy colour then it's the head gasket
  9. Alex Barnes
    I was riding it saturday and it was fine n go to start it today n its smoking n ive had a loom and carnt see any oil leaks and its coming from directly under the engine
  10. lee mason
    suzuki rg125 gamma
    dose the engine still run fine as it did before?
  11. Alex Barnes
    It runs fine theres just some smoke the smells of rubber
  12. lee mason
    suzuki rg125 gamma
    take it for a short ride see if anything feels wrong cause if it runs fine it cant be to bad of a pronblem, you said u think it coming from the clutch a ride will tell you if it is a clutch problem
    Mark farmer likes this.
  13. Alex Barnes
    Dont really wanna ride it when its smoking
  14. Mark farmer
    Mark farmer Member
    Push it down to the nearest garage then
  15. rustyscooter
    rustyscooter Active Member
    Aerox, Harley, Blade
    without seeing it it is difficult, but you keep saying it smells of rubber, the things that come to mind are, HT lead burning on the cylinder or exhaust pipe or possibly some of the wiring, or the variator clutch drive belt which might be rubbing or shredding, it wont take a minute to remove the casing and look.
