Idleing.
Discussion in 'General Scooter Discussion' started by Jamie, Jan 31, 2008.
  1. Jamie
    Right, before i start pulling the bike to peices i wanna know what im looking for, to avoid wasting time.
    my bike doesent even make the slightest attempt to idle on its own?, even with the tickover screwed right the way in?
    it started happening when i put oil in with the petrol to make sure the 70 kit had enougb oil, and it was oil fouling for ages, that has cleared up now, but i still have this problem, :rtfm:
    it makes it hard to warm the bike up in the mornings, and its annoying at traffic lights as i have to keep blipping the throttle to keep it alive
    any ideas?
    oh it also has a hard time starting? like 30 seconds on the electric start agitating the throttle and 3-4 kicks on the kick start at full throttle :(
  2. kyle1b1
    shouldnt need to use throttle to start it when the choke is on.
    choke work ?
    cleaned carb out ?
  3. Jamie
    well i was going to start with cleaning the carb , jsut wanted to make sure it couldnt be anything else before i start...
    and yeah never had a problem with the choke, it all worked fine til it was oil fouling
  4. kyle1b1
    i would check choke. might just be coincidence that its died when you used premix.
  5. Jamie
    but if it was the choke, wouldnt that mean it would idle fine when its warm?, it doesent idle fine, ever, i can go on a 50 mile drive and it wont even attempt to turn over once as soon as i come off the throttle
  6. kyle1b1
    ok. the idle speed being turned right down ?
    take filter off and have a look where slide is should be a few mm from bottom with no throttle applied at all.
  7. Jamie
    its like a third or just less up. as the idle screw is in full :nerd:
    i was thinking reeds mabye?
  8. kyle1b1
    could be just get out and have a look you lazy cunt :p
  9. Jamie
    i would but i lent my torx screw set to a mate about 4 months ago and aint seen em since :(
  10. CRAZY EYES
    CRAZY EYES New Member
    I had the same problem with my wife's RS125, and as you said it was the reeds!
    Also did it a little bit because the idle needle screw had worn a groove in the slide where it pushes, and was just sliding into the grove and not lifting the slide.
    Check both and go from there!
  11. Jamie
    wicked mate ill get this blokes case tomoro to get my tools back
    :nerd:
  12. Major Rel14b1lty
    Major Rel14b1lty New Member
    not suprised u aint got your torx screws back if you got his case.
  13. Jamie
    meant to say ill get oon the case lol
    if ya get me?
  14. Kieran
    Kieran Active Member
    st
    wont the case break if you get on it? :w00t:
  15. runner 180
    runner 180 New Member
    i had the same problem with my typhoon 172 if is a typhoon u need the black case that goes over the bore otherwise it will heat sized
  16. wobbly_trials
    crank seals.
  17. Ciaran
    Ciaran Active Member
    Reeds, that'll be why mine stalls like a cunt.
    Thankoo!
  18. Ciaran
    Bastard!
    Any ideas to where i can just pick up some reed petals?
  19. wobbly_trials
    scooter-attack
    buy CF sheet and cut your own.
  20. Ciaran
    Sounds like a plan wobbly.
