Idle mixture screw
Discussion in 'Scooter Tuning' started by stevie boy, Apr 21, 2008.
  1. stevie boy
    stevie boy New Member
    Well today i was fiddling with my carb as i have a e5 airfilter i have a 91 jet but kinda splutters guessing over fueling or sumit but anyways i turned the idle screw away from my self (to the left) 1/2 turn then 1 turn then upto 2 turns my bike got worse so i turned it to normal then 1/2, 1 turn etc upto 2 turns and it is running good but i thought you guys said turn it about 1 1/2 screws to the left it just made my bike worse so this is all i wanted to no why my bike runs good when turning it the other way thanks.
  2. SimonT
    SimonT New Member
    When I had a big jet and open filter, i had the mixture screw in pretty much all the way.... just cracked.....
    still miles too rich down low, even with an 80 jet.....
    now ive got a 74 and the airbox back on, and it behave much better....mixture screw is about a full turn out.
  3. capri dave
    capri dave Active Member
    sounds ok to me, screwing the (small) idle screw in richens the mix,
    and screwing out, weakens the mix ;)
  4. stevie boy
    good to hear dave thanks alot
  5. SimonT
    SimonT New Member
    you sure about that?
    pretty sure on mine, screw in for lean, out for rich....
  6. MiNoR cOnFuSiOn
    i can never really remember.. takes 2 secs to figure out ether way LOL
  7. alex_1966
    alex_1966 New Member
    yup
  8. stevie boy
    so which way is it lol i dont wana run lean but when i turned it outwards my bike bogged down more then finally wudnt start so i went back to normal and about 2 turns inwards helped loadz it went really good
  9. MiNoR cOnFuSiOn
    look, lean or rich means fuck all.. just find where it runs best. its only the idle mix.
  10. stevie boy
    lol somebody is in a bad mood all this fucking and shitting lol but they it is running sweet so cheerz
  11. SimonT
    SimonT New Member
    someones poking minor with a stick.....
    anyway...he is right... it only comes into action at idle.....
    your not going to damage the engine etc as the fuel mixture on throttle is determined by the main jet.
  12. capri dave
    I took a c.o meter to mine last summer and on a Dell 20.5mm carb screwing in richened the mixture and screwing out weakened the mixture ;)
    which as it goes was the opposite to what i was expecting, as car carbs work in the opposite manner!!!
    so i would presume the idle mixture screw on a Dell 20.5mm works like an Air bypass screw...(screwing in shuts the air off/richening the mix and vice versa) :D
    And just for the record bogging can mean too rich a mixture as well as too lean!!
    Also applies to an engine that pulls harder on 3/4 throttle and bogs on w.o.t,
    can be too lean as well as too rich ;)
  13. stevie boy
    ok thanks it is running seriously smooth atm so thats good the only slight problem is it will not idle if i sloww down for say.. some traffic light the bike will just slow down then finally cut out like i have switched the bike off and in the morning it idles high for about 2 minutes then drops and cuts out i have fiddled with the idle screw but not much happened :(
  14. eddiesmith
    eddiesmith Member
    thats exactly wot happened on mine after i had fiddled around with the idle mix, mine cut out becus everytime the revs droped it wud be runnin rich and my filter was gettin soaked! still does it actually but im gonna get a 70kit soon so i may aswell leave my bike running rich for a bit and hopefully it will run fine for the 70kit wivout a jet change :D
  15. MiNoR cOnFuSiOn
    reset the carb FULLY WARM.. the choke is making up for then poor ildmemix setting
  16. stevie boy
    is that an auto choke i have put a polini manual choke on now should i just fiddle around with the idle mixture moreit is at 2turns left so i will turn it 1/4 turn right see what tht does
  17. mca6969
    mca6969 New Member
    my aerox is doing the same and its only got 800km on it, when i turn it on cold it is quick as fuck but when it warms up the acceleration is really slow and then if i leave it it will eventually die out, it will only drive on full throtle as well :confused: never used to be like it
