hi, does gilera ice 50cc, have the same clock connection as gilera runner. has anybody tried to fit other clocks to the ice with modification of course. thanks
No, the speedo/connections are different, electronic speedo drive. You could make anything fit if you wanted to, all you need is wireing diagrams. I might have the wireing diagram for the ice clocks.
the speedo that i have at the moment is faded and when i press the back brake it fades even more, the speed stays at zero and doesnot move but the petrol level goes up and down, ive ordered a second hand speedo, gota wait n see if that works. how much does it cost to fit a aftermarket one or is it easy to fit it yourself??
You could get a KOSO aftermarket digital clock set, this should fit and have all the wireing info included.
the new clock is ok, but the speed sensor does not work, will a koso aftermarket speed sensor work with the original clocks???
