i need help with my typhoon 70s
Discussion in 'Scooter Tuning' started by gomz, Jul 15, 2008.
  1. gomz
    gomz New Member
    gilera 183
    hello my typhoon has got a molossi 70's kit ,4g rollers,the pm 59 curly 1 exhuast,a 21 mm delorto carb and im just wondering if any body knows what jet i should use and also when i full throttle the bike it bogz dwn nd loses power does anybodyhav any ideas
  2. Jasemc
    Jasemc New Member
    Just a heads up because your new, people will comment that there not called "70's" kits.
    They dont like that here ;)
  3. gomz
    gomz New Member
    gilera 183
    ok what shall i call them then lloll
  4. mhr-typhoon
    mhr-typhoon New Member
    with my setup i have got a 115main jet with open airfilter so if your running a open airfilter maybe about a 100-110
  5. gomz
    gomz New Member
    gilera 183
    erm i hav an airfilter on the carb..by teayim knew to this scooter tuning sndwhat shall i buy a 100 jet and a 110 jet or sumink can sombody pls hel me
  6. mhr-typhoon
    buy a 100, 110 and 115 and put a new spark plug in and then go aloge at full throttle for about 30 seconds then see what colour the insulater bit is it should be a tanned/brown colour when it is that colour your bike will be jetted perfecly
  7. typh70
    typh70 New Member
    i have exactyly same setup as u mate apart from a dopler air filter.
    i run my jet on a 78 and run the bike on a premix, works fine for me and my bikes hit a genuine 64-65. very good acceraltion too and not to demanding on petrol
  8. greg531
    greg531 Member
    I have a Polini Corsa, 17.5 carb, Molissi air/sponge filter, orginal air box, 4.5 rollers, and a 72 main jet, that is a tad rich....
    Go out and buy a pack of jets, then you can fine tune it....
    Those open air filters do drink a lot of gas....Petrol prices has come down in the USA, to $4.00 US, for Premium....which is cheap compared to the UK.
    I am getting around 40 mpg US...which is down from 70 before kitting....
    I am thinking about a overdrive kit, which one do you have?
  9. MiNoR cOnFuSiOn
    115 in a 21mm carb? are you for real? :confused:
    biggest its gonna be is around the 90 mark.
  10. alexsr70
    alexsr70 New Member
    what it is, Malossi Sport 70 for example or even just big bore kit loool
    yer exactly lol.
    i normally work from 85 to be on the rich side to be safe
