Im looking at getting a inner rotor, But my manual doesn't say which mm before tdc it should be sparking, Does anyone have a clue?
Assuming you are refering to an inner rotor ignition, they all have different settings depending on the brand. what ignition did you go for?
I havnt got one yet but I wanna know information when when I do otherwise I'll have to be hanging around, I was thinking either artek or doppler
Do you know what mm before tdc? It's complicated doing it by degrees, As I can get the timing tool screw it into the head and it's done instead of finding a degree wheel to bolt onto the crank and then doing all that
