i hate my speedfight 2 please help :(
Discussion in 'The Workshop' started by richard, Dec 5, 2013.
  1. richard
    richard New Member
    hi my name is richard i have a speedfight 100 and its doing my head in -.- first the cdi died so i bought a bypass took me ages to get it running again and then 2 weeks after that the exhaust snapped iv just bought one the same its a techigas and its now running like a bitch also it did leak alot of fuel from the carb i couldnt work out why i cleaned it all up and now it wont go over 5mph and when i stop revving it dies any help would be much appreciated
  2. leroya500
    leroya500 Active Member
    Find the source of the fuel leak, then reset the mixture on your carb and check your air filter
  3. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    Hi
    agree with leroy- but I'd go further.
    If it's being a pain - have that carb totally in bits, clean with carb cleaner, blast the bugger with compressed air & rebuild. Replace all fuel/air hoses and strip/rebuild the filter. Make sure everything is air tight & spotless.
    Check the admission pipe for cracks, empty the fuel tank, clean it, put a petrol filter when you replace the fuel pipe and put a new filter in the air box.
    It's often the little things -
    good luck.
  4. mally
    mally New Member
    after you clean carb put new plug in make sure filter on
  5. richard
    richard New Member
    :D Thank you for all your help im one happy chappy ish i still hate the dam thing iv taken it to bits more times than i care to remember. -.- But i striped the carb cleaned it with the carb cleaner left that to soak for about 30 mins. Put that back on the air box seems fine so i left that same with the fuel line all seems ok. Then i found the problem a really dumb moment on my part the rubber from the spark plug socket was still on the spark plug. So it was misfiring o_O duh! so after that i put it all back together took it for a drive and it wouldn't go over 30 at this point i could of tossed it in the lake. I found out its a restrictor in the exhaust so i took that out which took some doing i snapped a stud putting it back on o_O but now its running better than it ever has fingers crossed it stays that way :D
  6. Stevep
    It's a speedfight 100......................see you here again soon:oops:
  7. turbovetto
    tweaked ovetto
    If you de-restricted the exhaust - check your carburation / plug colour. Might need a richer main jet.
