** I AM SICK OF THIS !!!! ***
Discussion in 'The Workshop' started by Brooker_speedfight2, Nov 27, 2011.
  1. Brooker_speedfight2
    Brooker_speedfight2 Member
    Peugeot SpeedFight 2
    Now my fucking ped wont even get off the drive, it just keeps bogging and dying, iv done nothing to it. Its started doin it on its own, a few days ago it would be alright when its warmed up but now it wont even move and i need it for work !!!!! And before you ask, No i cant do a compression test and i dont want to as i believe its fine, 2, it has upgraded rollers and clutch springs and a stock exhaust. Iv tried messing with the fuel n air mixture but nothing changes no matter how much or how little i turn it ! HELP!?
  2. Brooker_speedfight2
    Also dont tell me to take the carb off because i cant, fuckin stupid airbox wont come out of the way its jamed between the engine and the frame
  3. tErr0
    You were told what to do to fix it and you didn't do it? Can't really complain.
  4. Brooker_speedfight2
    Iv never been told how to fix it you all just say different things, i need step by step instructions, and i have no money to buy anything.
  5. tErr0
    Then sell the scooter and get the bus? If you can't afford to run/fix something you own you shouldn't own it.
    spannerz likes this.
  6. Cjkt
    Cjkt Member
    Aerox
    If you dont like what people say on here dont use this site everyone is trying to help everyone for free? if you want it fixed take it to your mechanics but dont moan about people suggesting things to try help YOU
  7. Brooker_speedfight2
    Sorry about before i was quite angry haha, iv finally got my carb off :D Iv soaked it in boiling water, gonna leave it a few hours to dry and put it all back on and see if its made any difference
  8. nathan93
    Gilera Ice
    why have you soaked it in boiling water?
    also you need standard rollers clutch springs etc as it is a stock bike
  9. Brooker_speedfight2
    Im getting an exhaust soon so no point making it standard. and i got told boiling water does the trick, and it did, apart from it dying at like 15MPH
  10. stkflote
    stkflote Member
    zip 2t cat
    WHO ever told you to put boilin water on a carb, gave you a load of bullshit,
    you are not real mate
  11. nathan93
    Gilera Ice
    then store your scooter untill youve got an exhaust for it then and buy some rollers lighter than standard and jets larger and play around untill its set up right
  12. Brooker_speedfight2
    But its not a roller problem ! Im no expert but i can tell when its an engine/fuel problem. Iv cleaned the air filter, put fresh petrol in, it will run full throttle for around 3 seconds and be quite fast then sudenly it dies off and will only run half throttle :( Iv tried turning the tamper proof fuel/air mixture screw but still no difference, btw the spark plug is black and got thick oil around which means its running rich
  13. tErr0
    So you get good advice which you asked for then say no I don't need you advice because I know what I'm on about?
    Are you on crack or something?
    Edgar likes this.
  14. Brooker_speedfight2
    No, i just know certain things about engines as i was a car mechanic. What else could it be ? It runs and revvs fine on the stand, its just when riding it starts to die at full throttle when i reach like 15MPH, iv jus put in a brand new spark plug and cleaned air filter, still no difference :(
  15. tErr0
    Cars mechanics have no relevance to a two stroke CVT bike at all.
  16. decwhiteoak95
    decwhiteoak95 New Member
    could be compression related tbh mine did it and it turned out to be a scored barrel
  17. Brooker_speedfight2
    But it was working fine just a few days ago, i just dont get it, it pulls excelent at first then just dies, its not compression
  18. nathan93
    Gilera Ice
    dont rule something out if it hasnt been checked, its going to be the wrong rollers and wrong clutch springs, maybe jet aswell and youve changed the fuel and air mixture which is probably going to make things worse
  19. Brooker_speedfight2
    It was all running fine though up untill 3 days ago
  20. nathan93
    Gilera Ice
    check the belt, remove the rollers and check them also check the clutch aswell to see if its worn then
