Hungry Malossi Multivar! :(
Discussion in 'General Scooter Discussion' started by LukeD, Apr 7, 2013.
  1. LukeD
    LukeD ZIp-Zippity Zip
    Piaggio Zip 50
    Just wondering if anybody else has had the same problem as me with the multivar variator by malossi?
    It seems to be flat spotting rollers like nobodys business, and they are larger rollers than standard, and they cost £8 a set!
    My last set were flat spotted in around 4 months!
    I will upload a pic later of my last rollers to show the damage.
    Im probably just going to change the variator to a different one or go back to the standard, so open to suggestions
    Thanks
  2. MARSH
    Use std rollers of the same size/weight in the malossi variator.
  3. LukeD
    Piaggio Zip 50
    Std rollers are shorter in length though, as i said the malosso uses 19x15.5 mm rollers, so would 16x13 or 15x12mm rollers work ok in the variator?
  4. MARSH
    You make the rollers fit, file/drill them so there the weight that you need. As you know rollers are fitted one way in the variator so filing the rear side is not a problem.
