how to fit new piston kit aprilia sr 125?
Discussion in 'The Workshop' started by grgladwin, Oct 28, 2010.
  1. grgladwin
    grgladwin New Member
    my mate gave me his used typh 125 cylinder, and i got hold of a new piston kit for 33 quid, got rings on, just wondering do i put the arrow facing towards exhaust port or towards top of cylinder, this is my first time fitting a piston kit so could really do with a step by step guide if possible
  2. Admiwal Wabbit
    Admiwal Wabbit Member
    Arrow to the exhaust.
    I would suggest putting the piston slightly into the barrel, put a piston circlip in one end, then slide the whole thing over the barrel studs after putting the small end bearing in the crank, line it up, push in the gudgeon pin, put in the other circlip, push it all the way on. :)
    Make sure you check the cylinder condition before putting it together though bud.
  3. grgladwin
    ok mate thanks, and the cylinder looks fine no scratches or scores, ill let u no once its all sorted
  4. northrider
    northrider Member
    put some raw 2stroke on the small end bearing (the 1 that goes in the conrod) also put some on the sides of the piston and inside the barrel to prevent scoring you will also need to run the engine in
  5. Admiwal Wabbit
    The running in doesn't exactly matter, it's a used barrel, only a new piston.
    Don't worry about the running in really. if it was a full new kit then yeah a little bit of running in would be helpful.
  6. grgladwin
    ok ppl thanks, just got in from work so gonna put it all together in abit
