how to convert to premix?
Discussion in 'The Workshop' started by shiny_SR, Mar 26, 2011.
  1. shiny_SR
    shiny_SR Member
    runner vx
    ok, gonna convert to premix on monday before repairing my cylinder/piston,
    are these the correct steps to convert to premix on an aprilia sr 125?
    remove the cable going from oil pump to throttle cable splitter,
    remove the 2 oil pipes (1 thin 1 from carb and 1 thicker 1 from oil tank to pump)
    remove oil tank
    remove the oil pump and belt
    and thats it?
  2. tErr0
    You could also block off the feeds on the carb you are no longer using...
  3. shiny_SR
    shiny_SR Member
    runner vx
    cheers terro, i did notice that today, i will sort that out when i replace the cylinder, :)
  4. Batesy17
    Batesy17 Member
    To block the feed on the carb u can cut down the pipe from the pump to carb, clamp it and melt it together :)
    I heard someone say its a good trick somewhere. :whistle:
