How do you keep your scooter cooler in the summer?
Discussion in 'The Workshop' started by aeroxman87, Jul 27, 2016.
  1. aeroxman87
    aeroxman87 Member
    I have a aerox with a solid sport setup, and in the summer the engine get really hot, about 100 degrees C with full throttle.
    How can i best reduce the heat? Take out the termostat? Bigger radiator?
  2. twodogs
    twodogs Active Member
    scooters
    ride in the shade,,
    or ride slowwer
  3. aeroxman87
    aeroxman87 Member
    Thanks. Do you mean this tube shaped with cooler fins?
    I already have a aluminum radiator, that is standard on aerox.
    Do you know if it helps to take out the termostat in the summer? Or adding a second or one bigger radiator? Have you tried one of this things beafore with improvement?
    Thanks
  4. aeroxman87
    aeroxman87 Member
    Thank you. There is no cooling fan on aerox.
    I have a stage 6 temp sensor in the cylinder top so I can always see how many degrees it is. I've bought a new termostat, but i will first try without tomorrow. I report back how it goes
  5. aeroxman87
    aeroxman87 Member
    Thanks for all the advice. I've have taken out the termostat and the temperature dropped 20 degrees average. Now it is impossible to get it over 80. The radiator working pretty much
