How do you disconnect the cable going into the crank case?
Discussion in 'The Workshop' started by Jbis, Jun 26, 2013.
  1. Jbis
    Jbis New Member
    Sr50r
    I'm currently removing the engine out of my aprilia sr50r, the only thing that is stopping the engine from coming out is a small cable going into the cases I didn't even realise it was there when I was removing all the other parts. It connected to the throttle but I have no idea how to remove it someone help please thanks.
  2. chriscam13
    chriscam13 Member
    Oil pump cable? Going into the front near your variator?
    Sent from my Nexus 4 using Tapatalk 4 Beta
  3. Jbis
    Jbis New Member
    Sr50r
    yea how do you remove it?
  4. chriscam13
    chriscam13 Member
    Disconnect the cable from the oil pump then just pull it through if I remember right
  5. Jbis
    Jbis New Member
    Sr50r
    do I disconnect it from inside the side casing or is it somewhere else?
    cheers
  6. chriscam13
    chriscam13 Member
    Inside the side casing I believe
  7. millsy
    millsy "MORE SMOKE MORE POKE" ;)
    Gilera runner 172
    yes as above unhook from oil pump and pull cable threw adjuster
  8. Jbis
    Jbis New Member
    Sr50r
    cheers mate got it out now thanks alot :)
  9. Jbis
    Jbis New Member
    Sr50r
    Cheers mate got it out now thanks for the help.
  10. chriscam13
    chriscam13 Member
    No worries
