The problem I have is that i need a step by step guide! just learning how to do this stuff so the more detailed the better! Thanks
Lift your seat up, Under the seat is a Removable Panel. Remove it and your spark plug is underneath very easy to get to. then use a socket or a spanner if possible to then remove it, Turning anti clockwise
as stated above to remove it, unless its in a difficult position as mine is which requires the whole seat to be removed, but when replacing, do it up hand tight then get your socket wrench and give it a quarter to half a turn extra. Don't over tighten and everything will be good to go
