How do u get the gear case off?
Discussion in 'Scooter Tuning' started by typh-gilly99, Nov 27, 2009.
  1. typh-gilly99
    typh-gilly99 Member
    Typhoon 125 2T
    mine wont come off, ive tried sticking a flathead in the side but still no luck.
    anyone know?
  2. capri dave
    capri dave Active Member
    firstly make sure all the bolts are absolutely out....may sound silly but sometimes you miss 1 (ive done it) ;)
    and you may have to stick a thin flat head screw driver at the back of the case, and gently but firmly prise the bearing that sits inside the case off the clutch input shaft :)
  3. rideorcollide
    rideorcollide Active Member
    TYPH 172
    if its reallllly stiff i usually take off the hub and give the shaft a little tap with a hammer and it pushes it all out
  4. ma11b
    ma11b New Member
    nrg power
    same as above
    as you need to take the wheel off anyway to get the gears out
    give the output shaft a wobble and it should brake the seal
    remember that you put gasket selant around the gearbox cover so sometimes it sticks to the case
    i wouldnt use a flat head as it 'could' cause damage to the case if your not carefull.
    and make sure that there are no bolts left ;)
  5. capri dave
    aahh sorry if you read my reply, i thought he was talking about the transmission cover :hmm:
    yes in that case do not use a screw driver as if you damage the mateing surfaces, you may find the gearbox is no longer oil tight...
    as the other 2 said really :grin:
