hi i'm thinking about getting some mesh to put on some zip sp panels can i just glue it on with a glue gun or is there another way i have to do it thanks
Cellotape will do fine afterall none is going to see it just make sure its secure i wouldnt really want to put hot glue onto plastics
init man tape probs wudnt last till the end of the nite unless u use duck tape but glue gun or ducktape id say
abit bodge but hey what evr floats your boat what about using abnit of filler under and over the mesh behind the pannell would be structurely sound then?
is it a duct? then dont use duct tape!! glue it in/no nils/aryldite is good (you know, epoxy/glue used specvificly fo bonding plastic to metal) hot glue is a wase of ime.. wont ever melt a pannel tho
if its not going to be seen at the back, not sprayed at the back where the mesh is to be attached and theres plenty of overlap, just use high modulus silicone sealer (bath sealer)...once its gone off, it AINT going anywhere I have a 90cm x 60cm mirror held on a tiled bathroom wall with nothing but bath sealer and its been there 8 years to date
when i was 16 i used some special sort of glue-tape for mine, its used for sticking up roadsigns so i doubt itd go anywhere. i stuck it on the panel, heated it up with a hot air gun til it was really sticky and gooey and then put the mesh on. as you wont be able to get hold of any of this glue tape and double sided tape wont do, as people have said before araldite, no more nails, or bathroom sealant will do it. or alternativley if you can get hold of it TIGERSEAL is really good, its used for car bodywork.
