How do i convert to running premix ?
Discussion in 'General Scooter Discussion' started by CA Zip tuning, May 28, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    Ie heard its a good thing to do as ive got a ac zip and getting a 70s
  2. CA Zip tuning
  3. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    1. Remove the oil pump.
    2. Leave the oil pipe attached to the carb, but cut it off about an inch long and the block it with a screw.
    3. Upjet by 2 and start adding oil to the fuel, I use 100ml of good oil in 5 litres (50:1). With a 70 kit you may want more oil though
  4. CA Zip tuning
    what do u mean by cut it off and inch long and whats an ideal ratio for my 70s then
  5. Stathis
    Nrg Power 70cc
    whats the point of running premix mate??? you are not going for drag racing...
  6. oliwest
    oliwest Member
    aerox road legal pit
    You'll pros fuck it up.
    Do you no how to get the variation off? Pull it off then there's a spacer then a little belt going from the crank shaft to the oil pump.
    Look at the oil pump, undo the throttle cable an undo the oil pipes. Slide the pump off then the belt etc. Then pull your 2/ tank. The pipe connected from carbon to oil pump, cut the pipe down to a few cm, then plug it. Then get a mixing bottle an mix up a tank. Important tired an I've got auto correct on so if anything Iaa spelt weird its ntt me
