as you can see i cant see a bolt to undo and just looks like 2 bits of metal i can pull out? what shall i do and what tools do i need?? thanks
thanks nipples, so when i pull of them metal things they is somthing to pull of to reveal the nut? cause obv u cant undo tht circle thing? cheers nips
thanks nipples you was spot on just havent got a big enough socket to get it i only have a 22m and i think its like 24m :msn1:
surely u need a rench aswell vesta cant see him getting very far with jus a socket his brake and a hammer lol
its an "if i have to" situation id do this... i have the tool at home for any job i attempt to do.. as should EVERYONE. if you dont have the tool you shouldent CHOOSE to do the job. no real reason to do this tho as you cant change a tyre at the side of the road.
no the bikes in my garden and need to change the tyre since it has a puncture, not going to pay for a shop to take the wheel of when i should be able to do it if i have to borrow or buy an impact gun i will do so can i not do what nipples said and use a socket 24m and the back brake or lock the rear wheel??? and then pure hulk strengh?
no, even if you do its the only bolt holding your wheel on and i doubt you will be able to tighten it securely.. dont go silly wiht an impact wrench mind.. too tight and it snaps completly. hand tight (as much as you can holding the wheel/sitting on the bike) then impact wrench 5/6 clicks is usually fine. so you need one to refit the wheel, its a score from argos. why not
true say mr confusion i searched argos tho coudnt find one, would come in handy for the casings as well having an impact gun how much is a score? £100?
both false argos put it up to £30, maplins went out of stock quicker than a lager turns to piss Machine mart is the place, £19, made by clarke capri-dave was telling me his is donkeys old and still works a charm
^^ chill out nipples :rofl: anyway does anyone know if that £30 impact gun is any good it looks like its all made of plastic including the actual sockets?? :msn1: also can you stick on your own socket sizes? and will it have enough power??
i said the thing about the 24mm socket and a good rear brake... those cheap guns are intended to take wheel nuts off at the side of a road
