basicaly the cases i got one of the bearings is bollocksd and ive noticed they dont have the rubber seals in them either so ive ordered a new set and started to have a little read up on installing them and it says i need to measure how deep they were in before...wich i cant do as they arent in so does any one know the correct depth its an ac 125 new shape engine with a stock crank
is there not a lip for the seal to sit against ?? surely if u have to measure it would never be right n e way
yes that is correct.... the seal has to be far enough into the case so that it dont pop back out again from secondary crank case compression, but not so far in that it is actually rubbing on the bearing
ok problem is the cases i ws sold with "fresh bearings" that are fucked dont have any seals....so how do i find out how deep they need 2 go?
ok trouble is im using my old runner haynes manual so i have the option of lookin at the 125 lc engines or the 50 ac engines but thankyou for the info
alrite bruv need 2 chat 2 u btw say sumin 2 me wen u come on msn if i dont say sumin 2 u cos im half outside half inside
