How can you tell if a piagio typhoon is a 125
Discussion in 'General Scooter Discussion' started by TyphoonLagoon, Apr 11, 2009.
  1. TyphoonLagoon
    TyphoonLagoon New Member
    hello i want to buy a typhoon and the owner says its got a big bore kit? how can you tell?
    should the bike power wheelie with the power?
    should it be really loud?
    the handel bars vibrate and he says its because of the the big bore? is that true?
    also my friend said to cover the exhaust and the bike should cut out, it doesnt cut out? it dont even try to cut out so what could that be? cant see any smoke coming from anywhere?
    thanks for everyones help, btw good forum :)
  2. nibbles
    nibbles Active Member
    Re: How can you tell if a piagio typhoon is a 172?
    jus means the gaskets gone if it done cut out .the barrel will say malossi on the side. i would check if the front end is all tight and correct as that could be coz the race bearings have gone. though bikes do vibrate more wen they are powerful i dont think itd cause the bars to wobble bout lol. is it in long eaton?
  3. TyphoonLagoon
    no its not in long eaton, is they a typhoon in longeaton then? and i looked and the barrel didnt say 172, so it just means the gasket has gone that its blowing? so the pipe is ok? i fort the pipe might have been broken? the bike is in manchester, near a friend, longeaton would be better! and the bars dont wobbe they just vibrate?
  4. nibbles
    yh they dont say the cc i dont fink just malossi. vibrates at speed or jus wen its sat there ?. could be a crack in the pipe simply gtta look at it n try find a crack. if not its gasket jus means its blowing n u dont wanna be puttin ya hand over the end of can to often m8
  5. TyphoonLagoon
    well when its sat there it dont vibrate its when your riding it you can just feel the vibrating coming into your hands, and why should i not cover the exhaust pipe? also i coudnt see any cracks and the gasket looks like a 5mm one, also looks like a bit is missing cause u can see the bolt going into the gasket? is it easy to change a gasket?
  6. nibbles
    id still give the front end a good shake to make sure theres no play in it .sposed ta rek ya kit .gaskets easy m8 few bolts to take the pipe off then new one one the put pipe back on all simple tbh
  7. Stig
    Stig Well-Known Member
    EXUP1000
    if the vibration changes as the speed rises, its more than likely to need the wheel balancng. If its a weave, it could be tyre pressures or head bearings
  8. MiNoR cOnFuSiOn
    barrel says malossi. cant explain the diff.. can leave fucked bushes in a 125 and it will "feel" like a 172 (engine jumping about and the like)
    dont cover exhausts. gas comes out, stopping gas comming out fucks your engine (short awnser,) DONT DO IT
  9. star-172
    star-172 New Member
    Donkey
    Simple answers !
    RIDE it & Your know if its a 172 there is a few differences i believe
    Acceleration - Acceleration should be alot more powerfull than a standard 125
    Sound - The sound given from a 172 should be alot beefier than a standard 125
    There should be malossi engraved on the side of the barrel if not it has been sanded off in some kinda way.
  10. TyphoonLagoon
    yeh i can not find it on the barrel anywhere,
  11. star-172
    star-172 New Member
    Donkey
    yeah im guessing the studs should be there cause its an a/c cylinder, can u see 2 more if u look from the other side of the bike ?
  12. TyphoonLagoon
    :D
  13. alperin
    alperin Active Member
    aerox 180cc
    just buy the god damn thing lol you only live once and you learn from mistakes people cant tell you what engine it is from here.
  14. MiNoR cOnFuSiOn
    its too fast to be a 125? you can feel if its deffo a 172? you boys are DREAMING
    ive built plenty 125's 150's from stock barrels and they have been quicker than 172's... riding somthing is NO WAY of finding out whats on it. take it apart, LOOK/MESSURE the thing. sillynes
  15. TyphoonLagoon
    exactly, ^^
  16. MiNoR cOnFuSiOn
    ye, so pay for what you want or dont have it... simple really isnt it. you can ether afford somthing or you cant, they dont last forever, it will need replacing. if you cant afford 230 for a new barrel when it needs/you want one you cant afford a 172.. its QUITE simnple.. earn more
  17. RY4N172
    RY4N172 New Member
    bikes a steal for £150
    its fucking quick up to 60
    ,typh it must be a 125 because 70 clock speed .. if it had a 172 it would read more (personal view)
