How can I improve handling on a Piaggio NRG?
Discussion in 'General Scooter Discussion' started by Bradley Nixon, Feb 23, 2012.
  1. Bradley Nixon
    Piaggio NRG Power DT
  2. roxy boy
    roxy boy Well-Known Member
    roxi
    pump up ya tires ....get a longer suspension at back....
  3. Bradley Nixon
    What is standard suspension length on them?
  4. roxy boy
    roxi
    but you want ride it harder enuf to notice a difference ...
  5. roxy boy
    roxi
    dno but nrg are like tanks so just pump up ya tires and get a jack up
  6. Bradley Nixon
    what's a jack up? Haha
  7. roxy boy
    roxi
    its a block that goes under ya suspension and hires it about 2 inch
  8. roxy boy
    roxi
  9. Sketchytom
    Sketchytom Roach
    Rally 50 you get me
    get a stiffer rear shock
    i had a doppler one on the trekker it made it handle sick
    just it didnt dampen bumps under 30 ish verry well though
  10. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Try some heavier fork oil too?
  11. phil.s
    phil.s Active Member
    what nrg is it ? on mine its got quite stiff suspension so its fine id like it harder but its not good on the bumps when its so stiff but for bends its great theres nothing worse than spngy suspension half way round a bend at full tilt
  12. roxy boy
    roxi
    all you need to do is get a jack up and/or adjustable spring
  13. Bradley Nixon
    NRG Power DT 50 AC.
  14. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    That is terrible advise , there's nothing wrong with stock suspension on a nrg , providing it WORKS as is should , just like 80% of nrg's out there your forks are probably out of oil due to leaking seals or simply seized up , rebuild them using new oil seals and the correct grade and quantity of oil . Rear shocks are usually fairly decent on piaggio's however with age they as any other component will wear out , replace the rear shock for a stock one (unless you have some money to throw at it then go for something a bit more flash should you wish so) . Handling is also greatly effected by poor tire tread and wear pattern ( has to be evenly worn across the breadth of the tire) , so if your tires are crap so is the handling . And as mentioned above , check your tires pressures regularly , i normally go with 34psi rear and 32psi front depending on time of year and road conditions .
    Fitting a jack up will never improve handling , not from personal experience anyway.
  15. Sketchytom
    Sketchytom Roach
    Rally 50 you get me
    jack ups are for fat people that want the rear end to sit at normal hight when they sit on it!!!
  16. Bradley Nixon
    im not fat so thats all good.
  17. phil.s
    i have the same nrg as you and mine seems to be fine is yours really soft or something ?
  18. FiddyRox
    Freshen everything up as the fella above said, new seals and oil, and a new rear shock. Or at least take the shock off and grease up the pivots, it's little things that make it nice a smooth.
  19. roxy boy
    roxi
    an adjustable shock are only 30 odd quid and they do help as they puttin more preassure on the back wheel...why do you think they make them adjustable so you can adjust them to your liking
  20. roxy boy
    roxi
    they look better and then centre of gravity is bettr
