DONT bloody drill it out!!!!!!!!!!!!!!!! tap a groove in the side with a flat head n drive it round n out!!!!!!!! tap down on the head of the bolt to loosen it a lil bit b4 you tap the groove
Good ideas ^ If you can get to the head you can also cut a line into it (hacksaw) and use a flathead screw driver to get it out . Lots of Wd40 before hand though. I like the tap around idea though ^^
if youve ever got a broken bolt/thread and theres some left to grip on to, heat it up with a hot air gun and get some grips on it
I always hear about heat guns but have never seen one in action when you say grips do you mean "waterpump pliers" ? or molegrips? as molegrips arent as good as people say they are
i use mole grips or a vice if theres room.... but get some heat on it, get it real hot, and the broken stud or bolt should unscrew
^^ Recently used a set of Smurfs and they worked for me over molegrips so I have invested in some! Worth getting I would say! Got to get a heat gun at some point in my life though lol
have a look on ebay, i picked a hot air gun up brand new for about a tenner or something like that infact i just used it this week end to get a snapped exhaust stud out of a barrel i just sold to a lad
I hate rounded bolts, my worst nightmare when it comes to bikes, but ye the tapping, and heat gun method works just fine. :mrgreen:
mole grips all the way. Make sure they're a good set tho that'll take some serious pressure and abuse. Clamp em on REAL tight and then stick a lever through the middle of the jaws to rotate the bolt
