hosein the engine
Discussion in 'General Scooter Discussion' started by Porter898, Aug 21, 2013.
  1. Porter898
    Porter898 Member
    hi ,
    i was wondering if I hosed my engine of would it fuck it up
    its ot dirt all over it and wont to get it all off
    and would it be ok to hose off all the plastics aftr I have washed them
  2. Mark Emerson Trentham
    Your engine should be o.k.,it's your electric's where there might be a problem.,
    Hose all your plastics - after you've washed them?,
  3. Porter898
    Porter898 Member
    Right so I will try keep it all away from the electrics , and ov the carb
    Thanks
  4. andyn11
    andyn11 Active Member
    peugeot speedfight 2
    thats wut id do ... take care around electrics and the carb
  5. Porter898
    Porter898 Member
    Yea I have washed my old ped before with a jet wash and it fucked up the immobiliser but agave it time to dry out
    And then it was fine again , carbs the mane one I'm worried about .
    It should be fine if I put the box on it shouldn't it :/
  6. Mark Emerson Trentham
    If you're carb./airbox +,are'nt on your 'ped when you ?jetwash can't worry 'bout them can you?,
    Just make sure everythings blocked off properly/sealed against water/moisture.,
    Little prep. goes a long way.mk.
  7. Porter898
    Porter898 Member
    The carb and air box is on there mate
  8. Mark Emerson Trentham
    Was just saying take carb.an airbox off + anything else that may worry you an make sure all holes left
    are properly plugged - then wash it. :) .
  9. Porter898
    Porter898 Member
    Ahh ok mate yea ok will have to try fine something to plug up the holes that won't let water in
    Got any suggestion
  10. Mark Emerson Trentham
    Cling film + rubber bands,
    Plug holes with bog roll or kitchen towels case anything does! seep in /or/ to protect 'gainst condensation if you're
    using a hot/warm jetwash.,
    Pre-cut rubber bungs can be useful as well if you've got nothing to wrap c.film+r.ban around.
  11. Porter898
    Porter898 Member
    hosed it all off got most of the muck off it just got to wait for some gunk and elbow grease to come
    it get all the rest off .
    I took carb off and sealed up the hoses
    thanks for your help
    also when I look the carb off I looked to see that the jet was in it and it was a 54
    but I thought in speedfight 50
    it comes stand with 72
    anyways took it out and put a 85 in it an now runs a lot better
  12. Mark Emerson Trentham
