honda x8rs shredding polini belts
Discussion in 'The Workshop' started by smarty_boi, Jul 13, 2007.
  1. smarty_boi
    smarty_boi New Member
    i have a honda x8rs and in order to derestrict it you have to install a oversize variator, i have installed a polini speed control variator and a polini oversize kevlar belt to match and after about a a week or so of light use the top part of the belt was worn away, so i bought a new polini oversize kevlar belt same as the first 1 i bought and took it out for a spin to get it worn-in and it snapped on me. i have been using the standard variator and belt eversince only doing 40mph... not impressed :rtfm:
    does anyone know what could be causin the belt to snap and shred?
    cheers Adam
  2. wobbly_trials
    touching the case?
  3. smarty_boi
    could you explain how it could be touching the case, because ive looked in the casing to see if there is any thing that could disturb the belt and cannot find anything.
    do you think that the tourque spring could be to do with any thing, maybey too strong therefore crushing the belt?
  4. wobbly_trials
    nope, i think your belt is getting to the top of the variator and touching the transmission case (either at the top or bottom).
    look for clean metal in the case, this would indicate the belt rubbing.
  5. smarty_boi
    ok mate cheres
  6. Quattro
    Quattro New Member
    Honda X8RS/SZX50S
    I'm also into derestricting an X8RS but I don't know which oversize belt and oversize variator to use.
    Someone here who can help me with what parts I need to get ?
  7. MARSH
    There such an old model now, are parts still available?
