honda s wing
Discussion in 'Maxiscooter Tuning' started by Caroline, Sep 26, 2017.
  1. Caroline
    Caroline Honda s wing
    Bought a s wing and engine seized is there a easy fix please
  2. Stevep
    nope, take it out and strip it
  3. Caroline
    Or put new engine in
  4. Stevep
    Depends on your definition of "new".
    New new or ebay used new?
    New new yes great, expensive.
    Ebay used "new", still strip it, replace parts that are needed, then fit.
  5. Caroline
    Well the digital display has gone of. Also it cranks but won't start any help please
  6. Caroline
    F1 comes on for few then comes of.
  7. Stevep
    If it's cranking and not starting then the F1 light will come on, and it'll probably flash a few times too, it's a code thing they give out normally.
    But if the engine has siezed and is now moving again, then you need to do a compression test with a compression tester, not just sticking your finger in the hole and saying yes there must be compression because I can feel it.
    A PROPER TESTER.
    That's your first piont of call.
  8. Leeandjude
    Leeandjude New Member
    Hi Caroline. Look in my threads and you will see I had an S Wing with loads of problems but I've sorted them all now
    If you need advice please ask as I think I have literally rebuilt the whole thing!
    How many flashes are you getting?
